Use this procedure to display LLDP neighbor information.
  1. Enter Privileged EXEC mode:
    enable
  2. To view LLDP neighbor information, enter:
    show lldp neighbor {[port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}] | [summary {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}] [med]}
The following table defines parameters for the show lldp neighbor command.
Variable
Value
Displays LLDP neighbor information on the specified port.
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
med
Displays LLDP neighbors learned based on LLDP-MED TLV information.
Displays the summary of LLDP neighbors of a port or all ports on the switch.
